Home » Sponsored » Pi Speakers » making freq. response graph
making freq. response graph [message #41759] Mon, 30 June 2003 17:58 Go to next message
Hi Wayne,
If I have a 'scope and a swept audio generator, what else
is required to produce a frequency respose graph? Specifically,
what's required to plot the response of an active crossover?
Would I need some sort of a log amp to measure in dB? Does
the audio generator have to sweep at a particular rate? Is
there a PC program to do the same thing, maybe easier? The
active crossover I made a while ago seems to work really well
and I'd like to develop it more (variable freq, HF comp, etc).
Thx, Chris
Re: making freq. response graph [message #41760 is a reply to message #41759] Tue, 01 July 2003 00:12 Go to previous messageGo to next message
If you have a signal generator and scope, simply use a series of frequency points and measure the input and output voltages. This will allow you to plot a graph, which you can calibrate in linear voltage or in decibels. You'll probably want to scale with decibels, so convert voltage to decibels using the formula dB = 20log(Vout/Vin).
Re: making freq. response graph [message #41774 is a reply to message #41760] Tue, 01 July 2003 15:26 Go to previous messageGo to next message
Sorry, I wasn't clear. I want to plot to display on the
scope in real time. I guess I'd have to get the horizontal
input tied to the freq. sweep signal. That I don't have.
Chris
Re: making freq. response graph [message #41775 is a reply to message #41774] Tue, 01 July 2003 15:37 Go to previous message
You're right that if you want to have an automatic process then you'll need a mechanism that synchronizes the generator sweep with the measurement device. You could have your computer D/A generate the sweep and read it with its A/D. Then synchronization would be a matter of timing logic in your code. Alternately, if your signal generator has some sort of synchronization signal, perhaps you could read it programmatically. Either way, you'll need to have a mechanism in place.
Previous Topic: 511B update #3 Major Improvement!
Next Topic: Low distortion op-amp
Current Time: Sat Nov 14 15:30:40 CST 2026
