Home » Sponsored » Pi Speakers » Old gear lovers and the electronics savvy...
Old gear lovers and the electronics savvy... [message #41695] Sun, 22 June 2003 18:52 Go to next message
...please see my reciever restoration questions post on the vintage forum.
This was too off topic here, but I have come to trust the taste and advice of so many here. Click below if you like this kinda stuff.
Thanks!
Re: Old gear lovers and the electronics savvy... [message #41698 is a reply to message #41695] Sun, 22 June 2003 21:57 Go to previous message
If I understand you correctly, the receiver was made in the 1970's. I've not really experienced much trouble with electronics from the seventies, with most of it still working fine. The only parts I would expect trouble from would be electrolytic capacitors, rechargeable batteries and picture tubes. Stuff like coils and resistors almost never go bad, and same thing with transistors, diodes and integrated circuits. If they're used within their limits, they'll be fine for a lifetime. Even most of the capacitors of this era will outlast their owners, with a few exceptions such as electrolytics.
Now then, gear that's from the 1950's and back is a different story. I'd really like to use all-original parts, but find that the capacitors are usually leaky or completely open. Resistors and coils are usually fine, but obviously tubes will have a finite lifespan, just like light bulbs. And even the wire will often need to be replaced - The early plastic insulation doesn't stand the test of time, and if it isn't cloth, I'd suggest replacing the wire. You can buy spools of wire with cloth insulation from Antique Electronic Supply, and it looks appropriate for the age and will definitely last a long time.
Previous Topic: Is textured paint a problem for cabinets?
Next Topic: Is this a good deal
Current Time: Sat Nov 14 15:28:54 CST 2026
