Home » Sponsored » Pi Speakers » OK,noMac,So 2 same Woofers in a BR Box Software?
OK,noMac,So 2 same Woofers in a BR Box Software? [message #41683] Fri, 20 June 2003 15:44 Go to next message
-3db is currently offline  -3db
Thanks Gentlemen for your kind responses.
I appreciate your help.
If you know any free software which I can download which will easily do 2 woofers in a reflex box.
This would be helpful, and I am not sure how much choice I will have on this matter.
Sincerely,
-3db
Loudspeaker Software [message #41684 is a reply to message #41683] Fri, 20 June 2003 16:33 Go to previous messageGo to next message
PiAlign has a setting for "Qty," and entering "2" here will calculate dimensions for a dual woofer box. BoxPlot and LSPCad will also do multiple-driver calculations, so you can determine response with them.
Wayne
and once you get the numbers from PiAlign... [message #41686 is a reply to message #41683] Fri, 20 June 2003 18:24 Go to previous message
you can cook up cool graphs, various port options and box dimensions in BoxPlot. You can get boxplot from Pi Speakers website also.
Note: the multiple driver option is in the box parameters dialog box.
Thomas F.
Previous Topic: Parts Express 12" sub-woofer cabinet
Next Topic: :) I thought this day would never come...the speakers are complete
Current Time: Sat Nov 14 15:28:48 CST 2026
