Home » Sponsored » Pi Speakers » Corner horn question
Corner horn question [message #41420] Sun, 18 May 2003 22:35 Go to next message
Dave Callan is currently offline  Dave Callan
Hello Wayne (and others)
I just moved and am setting up a new listening room. I have been considering corner horns but I have a question about the suitability of my room. Dimensions are about 19'X 12' X 7.5'. The floor is carpet over concrete but upon closer inspection, the wall are just panelling over studs (insulated with fiber glass) with a concrete wall behind that. Will this construction present problems with a corner horn ? Should I beef up the walls (couple layers of drywall?) or stick with coventional BR speakers?
Thanks,
Dave
Corner horn answer [message #41422 is a reply to message #41420] Sun, 18 May 2003 23:44 Go to previous message
You actually don't want walls that are rigid. I know that's counter-intuitive, but the fact is that rigid walls cause sharp room modes. Having some panel flex in the walls and insulation behind them helps damp the room, much like having built-in bass traps.
Previous Topic: Power Handling of Pi Crossover
Next Topic: Altec 511B Ringing Update
Current Time: Sat Nov 14 15:30:15 CST 2026
