| horn for 2426 [message #41225] |
Mon, 05 May 2003 06:49  |
vladimir
Messages: 5 Registered: May 2009
Esquire |
Hi, I would like to ask you which horn is recommended for 2426h for 7pi pro. Is there also any DIY recommendation for the horn ? TIA, v.
| Re: horn for 2426 [message #41229 is a reply to message #41225] |
Mon, 05 May 2003 15:23   |
Messages: 19105 Registered: January 2001
I'd suggest the Eminence H290 or Bill Martinelli's 12" wood horn.Another great option is Martinelli's 17" horn. Since it's a little larger, it can be used at a lower frequency. It will work just as well up high and looks very attractive with the Professional Series seven π speaker because the width of the horn matches the width of the cabinet. Stage Series seven π loudspeaker at MAF 2003
The speaker shown above is a Stage Series seven π loudspeaker in the hotel room at the Midwest Audiofest. The Professional Series seven π uses the same size cabinet, so they look the same.
| Re: horn for 2426 [message #41240 is a reply to message #41229] |
Tue, 06 May 2003 23:43   |
vladimir
Esquire |
Thanks Wayne, Is there any plan for Martinelli 17" horn ? I also looked at this interesting site: http://vincent.brient.free.fr/pav_ronds.htm describing relatively easy way to construct round horn...looks interesting. Another Q: how important is sonic difference between stock eminence plastic horn and good dessigned wood horn ? thanks, v
| Re: horn for 2426 [message #41244 is a reply to message #41240] |
Wed, 07 May 2003 07:59   |
DRC
Messages: 169 Registered: May 2009
Master |
There are step-by-step instructions on his site (woodhorn,com) showing how he builds them. If you're highly skilled and have the right gear, have at it. Having read through the DIY page, I'd rather let the master craftsman do it. But that's just me. Keep your ears and your mind open.
| thanks [message #41279 is a reply to message #41225] |
Fri, 09 May 2003 00:03  |
vladimir
Esquire |
Thanks guys, I will start with stock Eminence H290 and I will try to build som wood horn maybe latter :-) v.
