Home » Sponsored » Pi Speakers » Home Theatre setup different Ohms
Home Theatre setup different Ohms [message #41083] Sun, 20 April 2003 12:55 Go to next message
edge4syn is currently offline  edge4syn
Hi all. I'm new to the audiophile world and have the opportunity to purchase an amazing set of speakers and center channel. The odd thing(or maybe not) is that the left and right as well as rear channels are all rated at 8ohms nominal while the centre channel is rated at 4ohms. Wondering what, if any problems I may run into, or should I avoid this situation altogether. Thanks.
edge
Re: Home Theatre setup different Ohms [message #41087 is a reply to message #41083] Sun, 20 April 2003 14:52 Go to previous message
Just make sure your amplifier can supply current to the load without clipping. Minimum impedance will be shown on the documentation that came with the amp. If you don't exceed the limits of your amp, you'll be just fine.
Previous Topic: cornerhorn Qs
Next Topic: Hey, Wayne! Check This Out.
Current Time: Sat Nov 14 15:13:39 CST 2026
