Home » Sponsored » Pi Speakers » To seal or not to seal
To seal or not to seal [message #40852] Fri, 04 April 2003 10:25 Go to next message
CatcCobra is currently offline  CatcCobra
Do I need to make the the seal around the drivers air tight on a ported center channel speaker? If so what is a good way to seal them to the box, without using the nasty black putty.
Re: To seal or not to seal [message #40854 is a reply to message #40852] Fri, 04 April 2003 11:12 Go to previous message
I usually feel around the driver for busts of air during large woofer excursions, and I don't apply a sealer if no air leaks are felt. This usually works if the drivers you use have gaskets already and your holes are cut so that there is some surface area between the driver and the baffle.
Previous Topic: Pi in Philly area?
Next Topic: 1 week before MAF
Current Time: Sat Nov 14 15:13:00 CST 2026
