Home » Sponsored » Pi Speakers » Eminence Delta series
Eminence Delta series [message #40715] Mon, 24 March 2003 14:09 Go to next message
Wayne, in a previous post you mentioned that the delta 10 would be suited to horn loading, I am interested in why the delta 12 should not be used?
Have you got any reccomendations on 8" drivers that can be horn loaded in a midrange tractrix horn?
Thanks!
Adrian
Re: Eminence Delta series [message #40717 is a reply to message #40715] Mon, 24 March 2003 15:34 Go to previous messageGo to next message
I'm sure you can make some models and find a horn that would work well with the Delta 12. But I would not use it in a midrange horn because there are other choices that are better suited, in my opinion. The Delta 10 works very nicely, for example. For an 8" driver, try the Alpha 8.
Re: Eminence Delta series [message #40720 is a reply to message #40717] Tue, 25 March 2003 06:25 Go to previous message
Hey Wayne,
I will try out and see how the response is using the Alpha 8. I hope its good, its a lot cheaper than many 12" drivers that I've considered :) Hopefully it matches my 2370's with PSD2002's nicely.
Thanks again,
Adrian
Previous Topic: JBL Tent amps: lots of watts for $$$
Next Topic: Sneak Preview: "The Two Towers: Minas Ithil and Minas Morgul"
Current Time: Sat Nov 14 15:12:36 CST 2026
