Home » Sponsored » Pi Speakers » box sizes and volume
box sizes and volume [message #40363] Fri, 21 February 2003 03:57 Go to next message
frog is currently offline  frog
Hey Wayne I have question about box size and volume. I am wondering if I keep the internal volume the same on a pair of studio 2 PI, but change the width/depth/height to 12" X12" X 22.85" would I be okay?
Re: box sizes and volume [message #40369 is a reply to message #40363] Fri, 21 February 2003 13:32 Go to previous messageGo to next message
That would probably be just fine - Certainly the volume is correct. But I'm a little concerned about having both the width and the depth equal. The frequency of this wavelength is 1125Hz, so it might make vocals a bit odd if this overtone generated standing waves inside the cabinet. I suggest that you break it up by making one of the two dimensions a half-inch smaller and the other a half-inch larger.
Re: box sizes and volume [message #40372 is a reply to message #40369] Sat, 22 February 2003 06:39 Go to previous message
Thanks for the info Wayne!
Previous Topic: Alesis RA-300 and Bi-Amped 10Pi - Good Match?
Next Topic: 4 Pi Theater Plans, Please
Current Time: Sat Nov 14 15:12:42 CST 2026
