Home » Sponsored » Pi Speakers » 16 Ohm crossover
16 Ohm crossover [message #39805] Thu, 09 January 2003 17:20 Go to next message
Wayne
I need your assistance....I found a set of 2470 1" compression drivers at a reasonable price (swap deal), I want to roll them off at 800Hz using the TOA Pi ciruit....I want to test them out but I don't know which way to factor the crossover for 16 Ohms....do I go up or down with values....
Kelly
Re: 16 Ohm crossover [message #39811 is a reply to message #39805] Fri, 10 January 2003 00:19 Go to previous messageGo to next message
I'd suggest that you model the circuit with Spice and tailor the circuit to give the response curve shown below. Butterworth values are pretty easy to find, but the compensation circuit values won't scale so easily. For example, the "stock" Butterworth values for an 8 ohm high-pass third-order are 8uF/0.6mH/22uF and the 16 ohm variant would be 4uF/1.2mH/12uF, so you can see that the caps are half and the coils are double when moving from an 8 ohm load to a 16 ohm load. But the compensation circuits really need to be modeled with a more accurate load representation, and you can't expect them to scale this way.
So download a copy of Spice, enter the values for your driver, and configure the circuit to give the response curve shown below.
Re: 16 Ohm crossover [message #39813 is a reply to message #39811] Fri, 10 January 2003 04:20 Go to previous message
Thx Wayne.....I'll give it a shot.
Kelly
Previous Topic: Really breaking the rules! Altec Model 19 specs?
Next Topic: Only three months until Pi's in the universe are sucked into the black hole known as
Current Time: Sat Nov 14 15:00:35 CST 2026
