Home » Sponsored » Pi Speakers » Question for Wayne
Question for Wayne [message #39524] Tue, 17 December 2002 15:01 Go to next message
wasteh202 is currently offline  wasteh202
Wayne, I am awaiting the kits for the Pi2 towers. I have a question about modifing the box sizes.
Keeping the 46" hight, how much would I be able to downsize the width from the 16" spec? Can I add to the 13" depth spec to make up for reducing the width? I would like to be able to get down to about 14" width if that is possible. Please let me know if this can be done and how I would modify the depth spec. Thanks
Altering dimensions [message #39526 is a reply to message #39524] Tue, 17 December 2002 15:28 Go to previous messageGo to next message
As long as the box volume remains the same, you can generally change dimensions slightly with no noticable difference. If you wanted a box that was 14" wide instead of 16", then you'd need to make the cabinet be 14 7/8" deep. You might make the box be 13" wide and 16" deep. That way you wouldn't have two dimensions so close to being equal.
The thing you want to be careful of is moving dimensions or positions around vertically. The height of the box and the vertical spacing of drivers should remain the same. These are critical dimensions chosen to minimize response abberations from internal standing waves.
Re: Altering dimensions [message #39531 is a reply to message #39526] Tue, 17 December 2002 20:18 Go to previous message
Wayne, thanks for answering my questions, you even gave me some options. I will begin on the boxes soon, thanks again.
Previous Topic: Pi-aligned line array?
Next Topic: Driver Spacing Question
Current Time: Sat Nov 14 15:01:15 CST 2026
