Home » Sponsored » Pi Speakers » 2Pi kit
2Pi kit [message #39196] Sun, 24 November 2002 10:08 Go to next message
pigmode is currently offline  pigmode
What all is included in the kit? What else is needed to complete the speakers?
Re: 2Pi kit [message #39197 is a reply to message #39196] Sun, 24 November 2002 13:04 Go to previous messageGo to next message
Kits include the speaker drivers, the connector panel, hook up wires, "π" logo decal and a printed copy of the plans. For larger speakers that incorporate a compression tweeter and crossover network, kits also include the crossover, tweeter compensation cable assembly, Zobel woofer damper, and all cable assemblies are completed and ready to install. Every kit containing a compression driver also includes the horn flare and the bolts to mount the driver to the horn.
Re: 2Pi kit [message #39200 is a reply to message #39197] Sun, 24 November 2002 16:33 Go to previous messageGo to next message
$54.31 for all of the drivers? Amazing.
Re: 2Pi kit [message #39201 is a reply to message #39200] Sun, 24 November 2002 17:00 Go to previous messageGo to next message
There's only two drivers, the woofer and the tweeter. Each kit has the components to build one loudspeaker system, and I'll agree with you that it's a good price. For a stereo pair, you'll need two kits.
Re: 2Pi kit [message #39243 is a reply to message #39201] Tue, 26 November 2002 18:26 Go to previous messageGo to next message
Wayne,
How many 4x8 sheets are needed to build a pair? Any other materials like insulation etc? Are they okay for HT use? What would I use for a center channel?
Do the 1 PIs sound the same as the 2 PI?
Re: 2Pi kit [message #39247 is a reply to message #39243] Tue, 26 November 2002 20:12 Go to previous message
The one π and two π speakers sound very similar, but the bass extension of the two π is a little deeper. Both make great surrounds or dialog speakers. The two π tower has much deeper bass response than either of them, and makes better left or right channel main speakers, in my opinion.
Build them as shown in the plans, with R11 or R13 insulation on three cabinet sides. The towers will also need insulation spanning the cross-section, laying on braces one-third the way up from the bottom and one-third the way down from the top of the cabinet.
Previous Topic: Eminence tweeter in 2 Pi towers
Next Topic: JBL 2426
Current Time: Sat Nov 14 15:01:07 CST 2026
