Home » Sponsored » Pi Speakers » Box sizes
Box sizes [message #39104] Mon, 18 November 2002 15:16 Go to next message
rude52 is currently offline  rude52
Hi Wayne,
Maybe I just need to try to work Boxplot and PiAlign, but I thought I would ask a (hopefully) quick question. I saw the really nice yellow 4pi Pros down the board and I like the look of that speaker, probably because it is a smaller size. When I looked at the specs, it is quite a bit smaller than the Thermionic or Theater 3s and 4s, but I know the Pros aren't always recommended for SETs. So, is it possible to downsize the boxes (NOT just adjust dimensions) to give up some bass response and/or efficiency but still use the recommended components (ie. Eminence alphas and PSD2002)?? Or are the components too sensitive to cabinet size and the Pro components just work better in a smaller box?? Thanks for your help.
Rich
Re: Box sizes [message #39107 is a reply to message #39104] Mon, 18 November 2002 15:55 Go to previous messageGo to next message
Don't try to use Eminence Alphas or Deltas in small boxes. They all have relatively high Q, especially the larger Alphas. This requires a large box or bass will be peaky. The Omegas and JBL 22xx woofers can be put in smaller boxes, because they have lower Q.
Re: Box sizes [message #39126 is a reply to message #39107] Tue, 19 November 2002 09:21 Go to previous message
Thanks Wayne!
Your answer was just about what I expected. Maybe I'll make some mock (cardboard) 3s or 4s to see if I can live with the size and then take the jump and put some together. Later
Rich
Previous Topic: Fotos of my visit to the Speakerman57
Next Topic: 1 Pi update, brief review
Current Time: Sat Nov 14 14:15:55 CST 2026
