Home » Sponsored » Pi Speakers » Seven Pi plans
Seven Pi plans [message #38924] Mon, 04 November 2002 12:42 Go to next message
artsybrute is currently offline  artsybrute
Hi,
Could you please send me the seven π plans?
Thanks.
Re: Seven Pi plans [message #38925 is a reply to message #38924] Mon, 04 November 2002 13:53 Go to previous messageGo to next message
Please tell me which model you'd like to build and I'd be happy to send you the plans. If you're unsure, there is more information about each of them at www.PiSpeakers.com/AvailableComponents.htm.
I'm thinking theater series... [message #38926 is a reply to message #38925] Mon, 04 November 2002 14:10 Go to previous messageGo to next message
Are there differences in construction, like compression chamber sizing? Does the sound quality differ from model to model?
I plan to use them as bass units, so I was going to check if I could cut down the height by leaving out any areas not devoted to the woofer, if any.
I figured that since I have a pair of very sensitive 15" Magnavox woofers hanging around, I'd try those out first. Is that a big mistake?
I'll need your E-Mail address [message #38928 is a reply to message #38926] Mon, 04 November 2002 15:26 Go to previous messageGo to next message
Each model is different, of different size and tuned frequency. Sound is generally the same, but obviously there are some differences. You might even try and design one specific to your woofer. Grab a copy of PiAlign and plug in the numbers for your Magnavox woofers. It will recommend cabinet size for you and you'll be able to build cabinets specific to your woofer. Be sure to read the "readme.txt" file included in the program distribution file for information about running the program and about the parameters required by the program. If you decide to go with one of my standard models, send me your E-Mail address and I'll send you the plans.
Re: I'll need your E-Mail address [message #38930 is a reply to message #38928] Mon, 04 November 2002 17:27 Go to previous messageGo to next message
Sorry, I didn't realize that my addy didn't link to my name in this forum.
Thank you again!
artsybrute@hotmail.com
You've got mail! [message #38931 is a reply to message #38930] Mon, 04 November 2002 17:37 Go to previous message
Previous Topic: 4Pi Pro vs Bottlehead Straight 8 (or Wayne is right again!)
Next Topic: Tweeter for Bass Guitar speaker with Altec 418B
Current Time: Sat Nov 14 14:51:27 CST 2026
