Home » Sponsored » Pi Speakers » @wayne
@wayne [message #38786] Tue, 22 October 2002 15:49 Go to next message
Tony is currently offline  Tony
Hi
here“s my version of the 2pi tower
H 117 cm ---> 46,06"
W 41 cm ---> 16,14"
D 33 cm ---> 12,99"
the internal volume is 130,6 liters
the diameter of the port is 11,4 cm ---> 4,48"
all 16mm mdf which is equal to 5/8"
are the dimensions correct????
one question about the coil?
the standart values at my local dealer are 0,47 mh or 0,56 mh
would it be ok to use a 0,47 mh coil
thx for your help
tony
@tony [message #38792 is a reply to message #38786] Tue, 22 October 2002 23:15 Go to previous messageGo to next message
Everything is perfect as you described; Use the 0.47mH coil and your speakers will be excellent!
Re: @wayne [message #38796 is a reply to message #38786] Wed, 23 October 2002 05:16 Go to previous message
Thx for your help
brgds tony
Previous Topic: Wayne: Recess drivers into baffle to control diffraction?
Next Topic: Pi4 and billies
Current Time: Sat Nov 14 14:51:25 CST 2026
