Home » Sponsored » Pi Speakers » How long would a 2-3/4" diameter port be for Studio 2pi?
How long would a 2-3/4" diameter port be for Studio 2pi? [message #38740] Sat, 19 October 2002 17:35 Go to next message
Patrick Kopson is currently offline  Patrick Kopson
Yes, I transposed the port and tweeter hole sizes. :{
5.75" long for 2.75" I.D. or 6.5" long for 2.88" I.D. [message #38741 is a reply to message #38740] Sat, 19 October 2002 18:24 Go to previous messageGo to next message
Hi Patrick!
You can use a 5 3/4" long duct that's 2 3/4" diameter with good results. The problem now will be finding a 2 3/4" diameter tube. You may want to go up to 3" port material, which actually has 2.88" inside diameter since wall thickness is 0.060". You can find this port material at www.PaperMart.com. If you choose the 3" diameter duct (2.88" I.D.), you'll want it to be 6 1/2" long.
Take care!
Wayne
Re: How long would a 2-3/4" diameter port be for Studio 2pi? [message #38744 is a reply to message #38740] Sun, 20 October 2002 03:13 Go to previous messageGo to next message
Hi Patrick,
I've got a piece of 2 3/4" o.d. .125" wall thickness acrylic tube that I would gladly give you if your interested. Send me an E-mail if so. Are you ever in the Cambridge/Somerville area during the day?
G.
2.5" I.D. port, 4.5" long [message #38749 is a reply to message #38744] Sun, 20 October 2002 13:21 Go to previous message
If a 2.5" I.D. port is used on a Studio Series two π Speaker, it should be 4.5" long.
Previous Topic: Building 2pi Towers - COMPLETE!
Next Topic: Wayne, why do you place your ports in the corner . . .
Current Time: Sat Nov 14 14:52:24 CST 2026
