Home » Sponsored » Pi Speakers » Over the Falls!
Over the Falls! [message #38710] Fri, 18 October 2002 08:31 Go to next message
DRC is currently offline  DRC
Wayne, Bill M, et al,
Wayne, thanks for the Studio Two and Two Tower Plans. I've decided I'd like to build something with compression drivers and the horn parked on top. Then I fell over woodhorn.com, which showed some of your stuff with his (freakin' gorgeous!) horns on top.
I'm wondering what driver in which of his horns would be most suitable for a 2A3 or 45 amp. (Currently Wanna Glows - mutated Paramours which may become a 45 amp), on top of which of your cabinets/drivers?
I'm wondering if the Studio Two or 2 Tower makes sense, or if I should go to the Thermionic Three. I don't want to go waayy huge, but I do need efficiency.
It also occurs to me that if the Studio 2's are a good choice, one could start with the Twos, then add the horns later, disconnecting the Piezo or crossing it over as a super tweet. . . .
Keep your ears and your mind open.
Re: Over the Falls! [message #38712 is a reply to message #38710] Fri, 18 October 2002 11:13 Go to previous messageGo to next message
JLapaire is currently offline  JLapaire
Hi Dave,
If you want, I'll loan you my Studio 2s after the November meet. You can take them apart or whatever.
Just a thought.
John
Re: Over the Falls! [message #38714 is a reply to message #38712] Fri, 18 October 2002 11:25 Go to previous message
John,
You, sir, are a prince. I may just take you up on that.
Thanks!
Previous Topic: 4Pi Theatre vs 4Pi Pro
Next Topic: A Question About Reflex Ports
Current Time: Sat Nov 14 14:51:41 CST 2026
