Home » Sponsored » Pi Speakers » Still more Theater 4 tweaking...
Still more Theater 4 tweaking... [message #38674] Wed, 16 October 2002 09:20 Go to next message
Since I can't leave the 4's well enough alone, I installed a pair of .56uF Alpha Core inductors in place of the stock Eminence .6uf and noticed a distinct gain in clarity. This completes the removal of the original stock crossover from these Pi's. The soundstage moved back a bit and I feel there is a reduction in the projection of certain undetermined frequencies which had been slightly bothering me. I do seem to sense a (very small) bit of new grain in the upper freq. but this may well be an exposure of some other upstream problem caused by the increased clarity. The coils are also brand new, so break-in is to be expected(at least by me). The tone of certain recordings has also changed which is very curious. The new sound is probably best described as darker with a more velvety and bronze-like character. The sense of dynamics hasn't changed,in fact the micro dynamics has possibly even improved! Over all, I like the change! More later....
Garland
Inductors or capicitors? [message #38677 is a reply to message #38674] Wed, 16 October 2002 10:18 Go to previous messageGo to next message
I'm assuming you're talking about inductors (coils) right.....the uF has me wondering.
Kelly
Inductors! Yes! I meant mH! Sorry. nt [message #38680 is a reply to message #38677] Wed, 16 October 2002 11:52 Go to previous messageGo to next message
nt
Re: Still more Theater 4 tweaking... [message #38681 is a reply to message #38674] Wed, 16 October 2002 12:34 Go to previous message
Neo is currently offline  Neo
Hi Garland,
Is it the tweeter coil you changed? It must be because the woofer coil is 1mH. I upgraded all my crossover components, except the tweeter coil. Hmmmm... and that makes a difference? It's not directly in the signal path... I wonder why ?
If you found a positive difference, I'll give it a try.
Thanks for the info...
Tom -
(remember me... we talked at the meeting at DRCope's place. I brought my rebuilt Pi 4 crossovers.)
Previous Topic: damping a H290 Horn
Next Topic: One Pi
Current Time: Sat Nov 14 14:51:20 CST 2026
