Home » Sponsored » Pi Speakers » Horn - install in cabinet or not?
Horn - install in cabinet or not? [message #38192] Thu, 05 September 2002 15:21 Go to next message
laoye is currently offline  laoye
I'm planning to build 4-PI pro speakers. I've been advised by one cabinet maker that it is better to build with the horn outside the box, placed freely on top of the cabinet. The idea is to offer some freedom to move it a bit with respect to the woofer cabinet.
My experience with speakers is that small toe-in adjustments do matter, but I've never fooled around with doing it with separate drivers. Could folks with experience here comment whether this is the way to enlightenment or madness?
Thanks in advance,
- Ken
4Pi pro [message #38194 is a reply to message #38192] Thu, 05 September 2002 15:45 Go to previous messageGo to next message
I can't comment on the sound of the horn on the outside vs the inside of the 4 pi's but I can tell you to wait till the horn is in your hand before you cut the hole! I went off of Eminence catalogue for the hole size and ended up having to make a spacer for inside the cabinet so the t-nuts would have something to stick into. The centerline of the bolt holes ended up being 1/8" from the cutout. If you use the H-290 I would make the hole 5 1/8 x 10 3/8. Also I'm not sure how it would impact the sound, but the flange on the H-290 is way thick, like 3/8", so I would also consider flushing it into the baffle to improve the esthetics of the unit. Hopefully Wayne will comment on that. Anyway....that's tonites project, hogging out the baffle, so please Wayne stop me if this is a bad plan. I'm hoping it's not cause it's my understanding that it improves the difracation of the high end when the tweeter is flushed in...hopefully this applies to horns as well.
Kelly
Re: Horn - install in cabinet or not? [message #38195 is a reply to message #38192] Thu, 05 September 2002 15:50 Go to previous messageGo to next message
Hi Ken!
Whether you mount the horn on top of the box or inside the box is up to you. It's a matter of aesthetics, really. If you mount the horn on top, be sure to keep the mouth flush with the face of the cabinet and keep the woofer to tweeter distance the same.
Wayne
Flush mount [message #38196 is a reply to message #38194] Thu, 05 September 2002 15:57 Go to previous messageGo to next message
There is a diffraction edge that's formed when the horn is not flush with the baffle, but it is too small to affect the sound. Still, a flush mount horn looks very nice.
I'd say, "do it!"
One more thing...actually 2 [message #38197 is a reply to message #38196] Thu, 05 September 2002 16:23 Go to previous messageGo to next message
Thx for the speedy response (that's one). Also I would consider doubling up the MDF on the baffle or use 1" material as it's going to be a little thin if you flush the horn all the way in. As far as the appearance thing...I think it's the fact that the port is flush with the baffle that makes the horn flange look out of place standing proud as it were...I'll let you know once I hog it out.
Kelly
THX again
you can try glueing [message #38199 is a reply to message #38197] Thu, 05 September 2002 18:06 Go to previous messageGo to next message
1x2's around the inside edge. I repaired an old AR2 speaker that way, for the same reason...the t-nuts were coming loose where the TOO THIN plywood edge crumbled. Alternative to flush mounting is build up the front baffle, cork panels work well, even another layer of brich ply or mdf, with holes to clear the woofer and horn flanges. Very strong. Sam
I thought about.... [message #38200 is a reply to message #38199] Thu, 05 September 2002 19:52 Go to previous message
adding another panel onto the front but I was concerned about messing with the port length.....it would be very difficult to shorten the wooden port on the 4Pi pros, it would have looked cool a solid hardwood baffle....next time.
Kelly
Previous Topic: Sub-Woofer cabinet
Next Topic: OT: How I Spent My Summer, by......
Current Time: Sat Nov 14 13:57:00 CST 2026
