Home » Sponsored » Pi Speakers » Sub-Woofer cabinet
Sub-Woofer cabinet [message #38149] Tue, 03 September 2002 11:41 Go to next message
JBLman is currently offline  JBLman
I plan to construct a subwoofer cabinet of approximately 9 cu ft (30x24x20) Is there some shape that is optimal or can the cabinet be within limits, any shape that adds up to 9 cubic feet. Also, whats the port size for a 9-10 cubic ft cabinet.
Re: Sub-Woofer cabinet [message #38151 is a reply to message #38149] Tue, 03 September 2002 12:08 Go to previous messageGo to next message
mikebake is currently offline  mikebake
What driver are you planning to use?
Re: Sub-Woofer cabinet [message #38163 is a reply to message #38151] Wed, 04 September 2002 07:41 Go to previous messageGo to next message
I'm planning to use a JBL 2245H
The 2245 is also [message #38167 is a reply to message #38163] Wed, 04 September 2002 11:02 Go to previous messageGo to next message
what I use. Here is what Wayne recommends for the 2245, from a previous email;
"The cabinets for 2245's should be 37" x 27" x 17" and should be made from 1" particle board if you don't mind the weight. If weight is an issue, then use 1" plywood and choose a good quality stock that is free of voids. The port should be 4.25" x 7.5" and 7.5" long." Those are the internal dimensions, and you need to brace the heck out of them to avoid panel resonance.
Dale Gernert (Robert H on the JBL forum) has alot of experience building sub boxes for JBL drivers. Here are some thoughts/info from our correspondence, concerning 2245 subs... (BTW, JBL's professional enclosure guide says for a single 2245 a 10cu footer tuned to 30, being 32x26.1x22.6 with 75 sq inches of vent area or 6 four inch ID duct tubes.)
Here is JBL's box they used, which I think is 8 cu ft if I recall.
http://www.jblpro.com/pub/obsolete/Low_Frequency_Enclosures1.pdf
"The 2245H in an 8 cubic footer is the classic fourth order butterworth maximally flat alignment that's for sure. If you are going to be moving these about, then 8 cubic feet is plenty enough to be hauling about unless you have some roadies to help :-)"
"The ONLY problem I have with the 2245H is it's enclosure volume requirement. If your listening room can support two 8 or 10 cubic foot enclosures then you are good to go. JBL went to great lengths designing the B460 (a home sub with a 2245) to make it as pleasing to look at as possible because most consumers would really balk at having a 4518 style box sitting in their living room. I have quite a bit of experience with factory B380's and B460's. My personal opinion is they suck. I mostly blame the BX63/BX63A for that. Additionally, the B380 at 4.5 cubic feet is simply too small and tuned too low for the 2235H without the EQ of the BX63/BX63A, the B460 is tuned too low for the 2245H without the EQ of the BX63/BX63A. Consumers must have felt the same way........
From experience, a 2235H in a 5 to 5.5 cubic foot enclosure tuned to 30 Hz and crossed over using a non EQ'd network such as the 5234A romps all over a factory B380/BX63. We installed many 2235H's into custom home theater systems. From experience, a 2245H in an 8 to 10 cubic foot enclosure tuned to 30 Hz and crossed over using a non EQ'd network such as the 5234A romps all over a factory B460/BX63. We only sold one set of 2245H's for a custom home theater system and this couple had us build the enclosures into the wall. The depth of the enclosures went into a service hallway that ran along the back of the listening room. The end result was spectacular. The 2245H can move so much air with so little effort and with minimal distortion it is truly the ultimate home subwoofer. It needs a big room to operate in though and a big enclosure to live in."
Re: The 2245 is also [message #38178 is a reply to message #38167] Wed, 04 September 2002 18:21 Go to previous messageGo to next message
yeah buddy!
this bud's for you
Correction [message #38181 is a reply to message #38167] Thu, 05 September 2002 00:12 Go to previous messageGo to next message
BTW, it's Robert G on the JBL forum, not Robert H. Sorry
Re: Sub-Woofer cabinet [message #38184 is a reply to message #38149] Thu, 05 September 2002 10:33 Go to previous message
You can make a wonderful system in 10 cubic feet. Shape won't matter if you crossover low, because wavelength is too large to develop standing waves inside the cabinet. I'd suggest either the π sub or the woofer cabinet of the seven π-18, both of which are about the size you're talking about.
Previous Topic: 4 P1 - 7 Pi conversion
Next Topic: Horn - install in cabinet or not?
Current Time: Sat Nov 14 13:57:33 CST 2026
