Home » Sponsored » Pi Speakers » Port Size 4-pi
Port Size 4-pi [message #38065] Tue, 27 August 2002 07:19 Go to next message
JBLman is currently offline  JBLman
The sketch prints for this speaker show a port sze of 3 1/2" x 6". I assume this is outside diameter and that the port is usually constructed of 3/4 in plywood. So it it the intent to have an inside diameter of 2" x 4 1/2" with a cross section of 9 square inches?
Re: Port Size 4-pi [message #38071 is a reply to message #38065] Tue, 27 August 2002 11:55 Go to previous messageGo to next message
The dimensions shown for the port are inside dimensions. The port is to be 3.5" x 6" and 10" long.
Re: Port Size 4-pi [message #38075 is a reply to message #38071] Tue, 27 August 2002 12:16 Go to previous messageGo to next message
Thanks, good thing I asked: From the plans I interpreted all the other measurments to be outside diameter. Was that right in terms of H x W x D ?
Re: Port Size 4-pi [message #38078 is a reply to message #38075] Tue, 27 August 2002 12:27 Go to previous message
That's right - All measurements are outside dimensions except those of the port, which show the size of the duct height, width and depth.
Previous Topic: Pi Subwoofer cabinet
Next Topic: Are Pi Speakers Suited For Nearfield Listening?
Current Time: Sat Nov 14 13:58:17 CST 2026
