Home » Sponsored » Pi Speakers » Tweaking speaker cabinet size
Tweaking speaker cabinet size [message #38029] Fri, 23 August 2002 14:29 Go to next message
JBLman is currently offline  JBLman
The p-4 15 stuffs a lot of material in a realitively small enclosure. What would be the effect of changing the dimensions to approximately 28x20x14. This is still smaller that the JBL SR4725X which uses the same drivers and larger cone. The SR4725X is 28x24x16, I believe. Would tweaking the cabinet size compromise the overall speaker design and performance?
Re: Tweaking speaker cabinet size [message #38031 is a reply to message #38029] Fri, 23 August 2002 15:29 Go to previous messageGo to next message
D. Kurfman is currently offline  D. Kurfman
The net effect should be almost negligible. The increased volume will reduce damping very slightly and increase response between 60 and 80 hz or so by about 1db. If this is a concern, it can be offset by tuning the box just a bit lower. This driver allows substantial freedom with the cabinet.
Dan
Re: Tweaking speaker cabinet size [message #38034 is a reply to message #38031] Fri, 23 August 2002 23:15 Go to previous message
That's true. The JBL 2226 works very well in cabinets from 2.0ft3 to 6.0ft3 tuned to 40Hz.
Previous Topic: Active X user's, system set up
Next Topic: plans for folded horn
Current Time: Sat Nov 14 13:57:48 CST 2026
