Home » Sponsored » Pi Speakers » What to do with Qts=1.20 driver?
What to do with Qts=1.20 driver? [message #37920] Wed, 21 August 2002 03:50 Go to next message
IvanZD is currently offline  IvanZD
Well, does anybody have idea, in what enclosure I can put a 13cm driver with Qts=1.20, Vas=25 l, fs=80 Hz. This is driver 4 ohm intended to use in car. But, I don't use it, and my friend wants to build something active to play with PC audiocard. Is it possible with this driver? It seems to be a huge enclosure because of Qts=1.20 and still with big ripple...
Anything to do?
Thanks in advance
Re: What to do with Qts=1.20 driver? [message #37926 is a reply to message #37920] Wed, 21 August 2002 07:59 Go to previous message
D. Kurfman is currently offline  D. Kurfman
Need a big box all right.
Jammed alignments per Keele:
Butterworth B4 207l fb 27 f3 27
Bessel BE4 172l fb 21 f3 33
BW Inter Order IB3 168l fb 27 f3 29
If I were determined to use the driver I would go with the BE4. Biggest problem is going to be the plus 3db peak around 100 hz. But, if you like your sound a little fat, this would work.
Dan
Previous Topic: Earth to replay, HELP!!
Next Topic: pi ratings
Current Time: Sat Nov 14 13:57:16 CST 2026
