Home » Sponsored » Pi Speakers » Corner loaded horns
Corner loaded horns [message #37897] Tue, 20 August 2002 11:42 Go to next message
Smrtislav is currently offline  Smrtislav
Hi all,
i was searching for a 2-3 way horn design to be used for home HiFi, and i've found it. The 7PI horns are so cool! As simple as a horn can be. I'm really impressed. My thanks go to the company. Your site is very inspiring!
S.
Greetings from the Czech Republic!
Re: Corner loaded horns [message #37899 is a reply to message #37897] Tue, 20 August 2002 14:17 Go to previous messageGo to next message
I'd be happy to send you the plans, so let me know which series you're interested in.
Re: Corner loaded horns [message #37903 is a reply to message #37899] Tue, 20 August 2002 16:17 Go to previous message
Unfortunatelly i'm leaving home to study in Denmark for a half year, so I won't be able to build them before february 2003:( I'm curious, how the bassreflex/horn loading go together. I think I won't need the plans, as there's enough info on your pages. But any informaton is welcome! I'll be using some local drivers, which should work according to simulations. I don't want to go cheap, but i don't want to financially ruin myself either. Maybe i'll try Selenium drivers, they have a good reputation amongst local DIYers.
I hope to get that PA kind of sound i hear on live rock concerts. So I think a PA horn system should give it to me. I'm planning to biamp, with some low powered tube amps, then the sound might be even better.
S.
Previous Topic: JBL 2446
Next Topic: 2 Pi Studio plans
Current Time: Sat Nov 14 13:57:27 CST 2026
