Home » Sponsored » Pi Speakers » T-nuts question
T-nuts question [message #37847] Sat, 17 August 2002 07:53 Go to next message
bqc is currently offline  bqc
How do you fasten the T-nuts to the baffle? Once you drill a hole
for it, do you just drive it in and sink the metal tabs into the
MDF and hope that the MDF will continue to grab them for years to
come, or do you put some liquid nail into the hole before driving
the T-nut into it to make sure the T-nut will never come loose.
Hot T-nuts, HotTnuts - Dizzy Gillespie [message #37850 is a reply to message #37847] Sat, 17 August 2002 10:37 Go to previous message
What you want to do is push the nut into the hole as far as you can with finger pressure, (which isn't very far) then run your screw from the outside as though you were installing the drivers but with a big fender washer to keep the screw from ruining the hole. Make sure all 3 tangs of the nut are biting the wood and tighten down until the tangs are fully into the wood.
It's time-consuming but the only way to keep those thangs seated. I see posts that recommend a dab of glue in the hole but I don't like to have to worry about gluing the screw, or screwing the glue.
Previous Topic: insulation thickness
Next Topic: kilomax vs. Magnum HO
Current Time: Sat Nov 14 13:56:41 CST 2026
