Home » Sponsored » Pi Speakers » Another question, sorry
Another question, sorry [message #37628] Sun, 04 August 2002 07:23 Go to next message
Jerry Parker is currently offline  Jerry Parker
Hey Wayne, we are going to try with these cabinet dimensions: 49 inches high, 18inches wide and 18" deep. Will there be any problems with the baffle width baffle step compensation? Is 18" going to be wide enough for the front baffle? Thanks again!
baffle step [message #37630 is a reply to message #37628] Sun, 04 August 2002 12:25 Go to previous message
As long as you keep them as close to a wall as you possibly can, this won't be an issue.
I personally think baffle step compensation is unnecessary and shouldn't be hardwired into any speakers unless you know thye will always be run in half space.
Keep them close to a wall and the effect should be negligable. None of Wayne's designs use a baffle step compensation circuit.
Adam
Previous Topic: Wayne, a problem with the port length
Next Topic: howcumzit?
Current Time: Sat Nov 14 13:58:26 CST 2026
