Home » Sponsored » Pi Speakers » Wayne, a little help, please?
Wayne, a little help, please? [message #37468] Wed, 24 July 2002 06:58 Go to next message
I've been playing with boxplot and can't seem to make it do what I want. I've decided to build the 2's with a rectangular, acoustically inert base 10" tall and put a polygon on top with all sides parallel but the front baffle which would slope toward the top 11 1/4 degrees.
That would put the tweeter at about 30" above ground and firing up.
I think the box should be 15wX22hX12.5d.
Could you check my figures, please?
Sounds right [message #37471 is a reply to message #37468] Wed, 24 July 2002 13:50 Go to previous messageGo to next message
Your dimensions sound about right, but if you'll make me a drawing and send it to me, I'll double check. I'm not sure about the volume because I'm not sure I'm visualizing your box shape right. But I see that you've offset some for the slanted top, and I expect that puts you where you need to be.
P.S. What happened to the "Cyclops
Now that you mention it (P.S.) [message #37474 is a reply to message #37471] Wed, 24 July 2002 15:19 Go to previous messageGo to next message
I was talked out of the idea (especially the tweeter on a stalk) but as you have laid down the gauntlet, you force me to create a 20 layer lamination or else use very expensive bending plywood. In lieu of pistols at dawn, I will send you a drawing and ask that you compute the dimensions for internal volume.
Full speed ahead.
Wayne delivering another Pi speaker
"I shall taunt you a second time" [message #37475 is a reply to message #37474] Wed, 24 July 2002 15:35 Go to previous message
I was really hoping to see the "tweeter on a stick." Maybe even just a short stalk?
Previous Topic: A little more low end please!
Next Topic: Pi speakers with ASL gear
Current Time: Sat Nov 14 13:58:39 CST 2026
