Home » Sponsored » Pi Speakers » Horn loaded midbass?
Horn loaded midbass? [message #37401] Sat, 20 July 2002 13:01 Go to next message
Anonymous
How do you figure out what 'boom' frequency a horn loaded
box using a 12" driver with a horn opening of 12"h x 12"w x 28"d ?
x |w |
exit
top view
| = walls
w = woofer
x = woofer mounted as if looking at x
Re: Horn loaded midbass? [message #37410 is a reply to message #37401] Sat, 20 July 2002 21:41 Go to previous message
I suggest using Hornresp to model the horn.
Previous Topic: Wayne sorry to spend your bandwith, but...even if Cyclops isn't for you....
Next Topic: Difference between reciever and shelf system =
Current Time: Sat Nov 14 13:56:57 CST 2026
