Home » Sponsored » Pi Speakers » Building a pair of 2 Pi in solid pine?
Building a pair of 2 Pi in solid pine? [message #37289] Sun, 14 July 2002 05:13 Go to next message
Erik Johansson is currently offline  Erik Johansson
Anyone tried this? I really love the looks of the finished pine and it´s also much cheaper than MDF + veneer. I can get it in 18mm and 25mm thick boards made from ~5cm wide pieces of pine.
/Erik
Re: Building a pair of 2 Pi in solid pine? [message #37292 is a reply to message #37289] Sun, 14 July 2002 11:43 Go to previous messageGo to next message
Build 'em in MDF and veneer - They'll sound better.
Re: Building a pair of 2 Pi in solid pine? [message #37298 is a reply to message #37292] Sun, 14 July 2002 12:42 Go to previous messageGo to next message
Will do so! The prices are almost the same for 16mm and 19mm MDF so I think I'll be going with 19mm. Also about the ports. You said my 50mm ID ports would be OK for the 2 Pi but I would still like to know, if I DO want to fine tune them, EXACTLY how long should I make them?
/Erik
Tolerance [message #37302 is a reply to message #37298] Sun, 14 July 2002 14:38 Go to previous messageGo to next message
The difference between what you've got and what was recommended was only 1.5mm, or about 0.06". Accuracy to sixty thousands of an inch here is completely fine.
Re: Building a pair of 2 Pi in solid pine? [message #37309 is a reply to message #37289] Mon, 15 July 2002 00:34 Go to previous messageGo to next message
vladimir4 is currently offline  vladimir4
Hi Eric,
I’m just doing this: I rebuild my 2 Pi (chipboard 2Pi box)
with 27 mm solid pine.
I changed also dimensions to tower-like look:
internal dimensions respects the ratio 1:1.402:1.202
(which is known as very good sounding).
I multiplied 1.202 by factor of 3 (allowed) so my box is internally
204 x 292 x 734 mm (43.5 liter, minus Alpha-10 1L and braces 2L).
The tweeter is golden-placed (asymmetrically, 0.618 from the top, 1.000
from one side and 1.618 from another side - this improve imaging).
Alpha-10 is also placed at the 1/3 of internal height.
My port is 50 mm internally and lengths from 40 mm to 100 mm works
fine. Varying the length of the port has more impact on the midrange clarity than on the bass extension (?!)
The first one is ready and playing (not glued, no braces and no
stuffing material at the moment). Sound ? Very promising, but
I prefer to spend some time to critical listening before review it.
Photos will be available soon.
Vladimir.
Re: Tolerance [message #37312 is a reply to message #37302] Mon, 15 July 2002 10:04 Go to previous messageGo to next message
Here is a picture of the ports I will be using. As you can see it's outer edge will extend about 2.5mm from the baffle (if I don't recess it which I don't have the tools to do) due to the flange with the screw holes. From where do I measure the length of the port? From where it starts (2.5mm out from the front baffle) or from the outside of the baffle?
/Erik
Re: Tolerance [message #37313 is a reply to message #37312] Mon, 15 July 2002 10:56 Go to previous messageGo to next message
Port length is total path length, from end to end. The sound doesn't care whether part of the port is formed by the baffle - all that matters is total length.
Re: Tolerance [message #37314 is a reply to message #37313] Mon, 15 July 2002 11:15 Go to previous messageGo to next message
Ok I got it. I didn't know if I should measure the entire inside of the tube or how long into the cabinet. But now I know it's the internal length of the tube.
Thanks, will get some pictures of the project (We'll be building 2 pairs of 2 Pi).
/Erik
Re: Tolerance [message #37335 is a reply to message #37312] Mon, 15 July 2002 19:36 Go to previous message
Why don't you put the flange on the inside of the box so it, and it's screws, don't show. Add the thickness of the box to the port, of course.Just paint the inside edge of the hole black and put a little sealant under the flange.
Previous Topic: T/S on the JBL 115H woofer
Next Topic: Wayne or anybody: L-pad values
Current Time: Sat Nov 14 13:57:05 CST 2026
