Home » Sponsored » Pi Speakers » Isobaric with a pair of Eminenece Beta 15's.
Isobaric with a pair of Eminenece Beta 15's. [message #37114] Sun, 30 June 2002 03:56 Go to next message
Andy.G is currently offline  Andy.G
about 120L tuned just about 40Hz, purpose - PA sub.
What chance you reckon Wayne?
Re: Isobaric with a pair of Eminenece Beta 15's. [message #37115 is a reply to message #37114] Sun, 30 June 2002 10:57 Go to previous messageGo to next message
Isobaric will increase moving mass and motor, but I'm not sure Beta 15's are the kind of speaker you'd want to run that way.
Re: Isobaric with a pair of Eminenece Beta 15's. [message #37116 is a reply to message #37114] Sun, 30 June 2002 14:21 Go to previous messageGo to next message
Should play fairly loud, but the box peaks nearly 5db at 62 hz.
I don't know what they cost, but I imagine you could get a single Kappa 15lf for the price of two of the betas. Run it five cubes (140 litres) tuned to 40 Hz with a pair of 4" ports. You'll get great output, and this thing goes damn *low* all things considering... To me it sounds flat to 30 Hz almost. It's one of the best low frequency drivers I have found from eminence that isn't too pricey and will run in a pretty small box.
You'll get more output than the betas (same sensitivity, but no power compression) with flat response, good sound and surprisingly deep bass.
Adam
Re: Isobaric with a pair of Eminenece Beta 15's. [message #37118 is a reply to message #37116] Sun, 30 June 2002 16:11 Go to previous messageGo to next message
Trouble is that I have a pair of bet 15's sitting on the shelf, just trying to figure how to use them best ! Thanks for the suggestion though :-))
Re: Isobaric with a pair of Eminenece Beta 15's. [message #37119 is a reply to message #37118] Sun, 30 June 2002 16:31 Go to previous message
Oh ok, I kinda figured that.
Things will be a bit better if you use a larger box... Like at least 5-6 cuft.
Adam
Previous Topic: Passive Radiator versus Port
Next Topic: plans for studio 2 pi
Current Time: Tue Sep 22 09:43:39 CDT 2026
