Home » Sponsored » Pi Speakers » Another question, Wayne?
Another question, Wayne? [message #37029] Fri, 21 June 2002 05:39 Go to next message
Edwin is currently offline  Edwin
Hi Wayne,
How do you glue the dampening material? Do you just glue the sides or do you glue the whole surface?
Thanks,
Edwin
Another answer, Edwin [message #37033 is a reply to message #37029] Fri, 21 June 2002 11:52 Go to previous messageGo to next message
I use white glue to fasten the insulation. Just run a few lines of glue the full length of the panel to be covered and about 2" apart.
contact cement can be real fun [message #37034 is a reply to message #37033] Fri, 21 June 2002 12:22 Go to previous messageGo to next message
especially when you are painting it on the inside walls of a 73 Dodge Van before insulating and paneling. Same "event" also involved my uncle scratching his head while I cut a hole in the roof for a vent:)
The one section behind the drivers seat "just never got paneled" because it was a strange, compound curved area. The contact cement alone held that R13 vertical and well attached for years. We had just stuck the bare glass side against the tacky cement, and it adhered well.
If white glue works, it would be much less fun, but safer for attaching the R13 to the walls.
Depending on the enclosure size, sometimes you would be surprised at how well the glass will remain in place just stuffed in there against a wall.
The bottom piece never can shift, unless you turn the speaker upside down. The rear wall piece of glass, if fitted snug side to side, stays in place also. The one side wall panel of glass will also stay in place, if sized right. My glass panels are spaced away from the walls by 1x2's glued to the walls as needed.
YMMV, you can always staple or glue later if getting it to stay by itself does not work out. Sam
long sleeve shirt, latex gloves, and big ass shears help a lot. the more carefully you peel away the unwanted paper from the glass, the better it "stays together" for stuffing into place later.
Re: Another answer, Edwin [message #37036 is a reply to message #37033] Fri, 21 June 2002 14:27 Go to previous messageGo to next message
Hi Wayne,
How about using a glue gun. Does the glue that comes with it okay?
Edwin
Re: Another answer, Edwin [message #37037 is a reply to message #37036] Fri, 21 June 2002 16:12 Go to previous messageGo to next message
There are probably several glues that will work just fine. Try it on a sample piece and see.
Re: contact cement can be real fun [message #37038 is a reply to message #37034] Fri, 21 June 2002 17:26 Go to previous messageGo to next message
RJW is currently offline  RJW
And white glue is cheap and easy. Glue Gun; hot glue or caulking gun/liquid nails? Or PL 400 (construction floor glue). Go delux and use yellow glue.:^)
Question; you use R-13 with out paper or plastic (bats), Right?
Ron
Re: spray glue [message #37039 is a reply to message #37036] Fri, 21 June 2002 18:09 Go to previous messageGo to next message
I like to use the 3M spray on adhesive (contact cement) it doesnt smell like the good stuff but it works very well and it makes the job go fast. This stuff is more expensive than the other methods the guys talked about.
And for the port hole, if your not into looking at yellow fiberglass through the port opening. spray a little flat black paint in the port to make it less noticable.
Bill
peel the paper away(nt) [message #37040 is a reply to message #37038] Fri, 21 June 2002 19:22 Go to previous messageGo to next message
nt
You can get it without [message #37049 is a reply to message #37040] Sat, 22 June 2002 13:19 Go to previous message
No text
Previous Topic: new project
Next Topic: D'appolito configuration
Current Time: Sat Nov 14 13:48:01 CST 2026
