Home » Sponsored » Pi Speakers » Pi center channel and sub
Pi center channel and sub [message #36756] Tue, 04 June 2002 06:49 Go to next message
mhammill is currently offline  mhammill
Grettings,
I'm new to AV setups and I will still listen to just the 4Pi's and foreplay paramour combination for music BUT...
I'm looking for suggestions for a center channel and subwoofer to go with the Theater 4Pi front and studio 2Pi rears I'm building.
I want to use the same horn as the 4Pi in the center but my space is at a premium (I really have no idea how I'm going to fit all this in my living room and not freakout my wife) so I will need to use something like 2 6" woofers horizontaly. Alpha 6 comes to mind, but how do I deal with the impedence issue? Run the woofers in series 16 ohm?
Any other drivers that would allow me to use 5 low powered set amps like paramours in this config?
I have a NHT 1259 250watt subwoofer but it doesn't seem right to use a 12" sub with 15" mains, I was thinking of more like a 15-18" driver in a small box with some EQ to cover the effects.
Any Ideas would be welcome.
Re: Pi center channel and sub [message #36757 is a reply to message #36756] Tue, 04 June 2002 07:19 Go to previous messageGo to next message
If you use the right 12" woofer, there's nothing wrong with doing that.
The NHT 1259 sounds pretty good, I used to own one, but it does not play very loud.
For true subwoofer duty, I personally recommend an Adire Audio Tempest from http://www.adireaudio.com . These drivers sound excellent in a 5 cuft box, with two 4" diameter ports 12" long, and they play extremely deep. I speak from first hand experience. They also don't require a lot of power. They will keep up with your front mains at pretty much any SPL level they can throw out, except at extremely high output.
Adam
Re: Pi center channel and sub [message #36761 is a reply to message #36757] Tue, 04 June 2002 09:31 Go to previous messageGo to next message
Bugman is currently offline  Bugman
Madisound sells the Eminence Tempest (15") driver for about $150.00 if you want to go DIY. I believe a sealed enclosure is the best way to go with it.
Re: Pi center channel and sub [message #36762 is a reply to message #36761] Tue, 04 June 2002 10:19 Go to previous message
A sealed enclosure will work, but IMO, they are simply better ported. Very similar sound, superior output and extension. Especially in a house.
Again, I speak 1st hand.
Adam
Previous Topic: question about r13 vs acoustic foam for dampening
Next Topic: Pi & Berning ZOTL
Current Time: Sat Nov 14 13:47:04 CST 2026
