Home » Sponsored » Pi Speakers » Progress on four Pi's
Progress on four Pi's [message #36659] Sun, 26 May 2002 16:02 Go to next message
Well I guess they aren't exactly four pi's, but very similar crossover and enclosure.
A LOT of bracing. It took me all weekend to build this one. I'm gonna sand her down and paint it this really dark gray colour. Should look really nice. These are the ones I'm planning on selling if there's a buyer.
Adam
Re: Progress on four Pi's [message #36660 is a reply to message #36659] Sun, 26 May 2002 16:45 Go to previous messageGo to next message
Colin Fritzke is currently offline  Colin Fritzke
Adam,
Those look really well-built... good job! What's the overall box volume and tuning?
Cheers from Calgary,
Colin
P.S. - Just finished staining my Premium Stage Four Pi's. Just a couple of coats of clear varathane, some black paint on the front and back and then the components get installed. Pics coming soon!
Re: Progress on four Pi's [message #36661 is a reply to message #36660] Sun, 26 May 2002 16:54 Go to previous messageGo to next message
Thanks, can't wait to see yours too.
Adam
Vb and Fb [message #36662 is a reply to message #36660] Sun, 26 May 2002 16:56 Go to previous messageGo to next message
Sorry forgot to mention those... I'm not exactly sure what the box volume is after all the bracing, but I designed it to be 5 cuft tuned to 40 Hz. it's probably slightly smaller than that.
Adam
colin, let us know how they sound...... [message #36706 is a reply to message #36660] Wed, 29 May 2002 19:21 Go to previous messageGo to next message
and what amp are you using? i've found bi-amping the 4 pi's works best, solid state for the bottom & tubes for the top. bass seems to diminish when running tubes on the bottom, unless your running 300b's.
cheers,
george
Re: colin, let us know how they sound...... [message #36708 is a reply to message #36706] Thu, 30 May 2002 04:55 Go to previous messageGo to next message
George,
What kind of tube amp were you using on your 4 Pi's? With my 2A3 Paramours I have more than enough bass. Are your 4's Theater 4's?
G.
Re: colin, let us know how they sound...... [message #36710 is a reply to message #36708] Thu, 30 May 2002 05:29 Go to previous message
hi garland, i have premium stage 4 pi's with the kilomax woofer. it's impedance at resonance is quite high. at lima i ran them with a kr18bsi 300b tube amp and it was fine but with lesser tube amps i miss the bottom end. at home i run a mission solid state for the bottom and a pair of quad II monoblocs for the top.
cheers,
george
Previous Topic: question about fasteners and dampening
Next Topic: Studio 2's - First Impressions (very long)
Current Time: Sat Nov 14 13:47:01 CST 2026
