Home » Sponsored » Pi Speakers » Speaker mounting
Speaker mounting [message #36381] Fri, 10 May 2002 07:15 Go to next message
I received my Thermionic 3pi kits last night and began final assembly into the cabinets. I have to say that the quality of parts that Wayne has supplied is outstanding. Easy to work with, great build quality.
I have one quick question before I get too far.. I notice there isn't any gasket tape. Should I get some for under the horn and under the woofer?
Thanks!
Steve
Re: Speaker mounting [message #36384 is a reply to message #36381] Fri, 10 May 2002 07:49 Go to previous messageGo to next message
None of my speakers have ever used sealing around horn lenses or woofer flanges, and I've never had problems with leaks.
Adam
It wouldn't be prudent.... [message #36385 is a reply to message #36381] Fri, 10 May 2002 09:27 Go to previous message
not to use a sealer like 'Frost King' finger tip caulk. a.k.a. Mortite. Available at Depot, Lowes, Tru-Valu, etc.
It couldn't hurt.
Previous Topic: Ping sam P.
Next Topic: the skinheads have left.................
Current Time: Sat Nov 14 13:47:56 CST 2026
