Home » Sponsored » Pi Speakers » Eminence Omega pro 18" --cant find box volume
Eminence Omega pro 18" --cant find box volume [message #36204] Wed, 01 May 2002 15:54 Go to next message
Mikeyboi is currently offline  Mikeyboi
Hello- I need some serious help- I've been trying for days to tune a box for an Omega pro (Eminence) 18" driver- I need it to go down to at least 38hz -3db up to say 300Hz, its for bass guitar. I cant seem to design anything below 58hz -3db and thats with a 2.253ft^3 enclosure tuned to 47.63 hz. Everything I try puts a hell of a spike at 58 hz and a 1.2db dip at 100hz. Its getting frustrating. Any help would be extremely appreciated. Thank you so much- have a great day
Mikeyboi
Re: Eminence Omega pro 18" --cant find box volume [message #36206 is a reply to message #36204] Wed, 01 May 2002 16:06 Go to previous messageGo to next message
freddyi is currently offline  freddyi
Hi
going by filter theory a jammed BW would be ~4.1cu.ft and tuned to 47Hz with f3 of 47 and Be4 of same volume tuned to ~38hz with f3 of about 58hz - did you simulate for boxes in ~4-5cu.ft. range tuned about 1/3-1/2 octave above 30hz? - one guy says a Karlson's front chamber air mass will effectively shift qes upwards and fs downwards allowing a different response to be achieved than with regular VB
Freddy
Re: Eminence Omega pro 18" --cant find box volume [message #36207 is a reply to message #36204] Wed, 01 May 2002 16:10 Go to previous messageGo to next message
I can't do a simulation for you right now because my computer is messed up, but I'll tell ya right now that the low Q of the omega 18's will make them very difficult to get deep bass response out of them.
However, if you send me an e-mail I'll get back to you as soon as my computer is running properly again.
Can you use any different drivers than the omega 18"?
Adam
Re: Eminence Omega pro 18" --cant find box volume [message #36211 is a reply to message #36204] Wed, 01 May 2002 17:01 Go to previous messageGo to next message
150 L tuned to 40 Hz will go to an F3 of 38Hz with a 1.3 Db dip...considering most people need 3Db to hear any difference that's probably as good as it's going to get with that driver.
Kelly
Re: Eminence Omega pro 18" --cant find box volume [message #36224 is a reply to message #36206] Thu, 02 May 2002 15:08 Go to previous message
My cab is about 4.812 ft^3 tuned to 47hz-- Still can't get a good flow- Is it true that the human ear cant perceive anything under 3db in change? - Its frustrating paying 200 clams for a speaker and not getting the performance youd expect- I know better now.
Thanks so much for your help everyone
Previous Topic: Question for wayne
Next Topic: Plans needed
Current Time: Sat Nov 14 13:31:37 CST 2026
