Home » Sponsored » Pi Speakers » attenuating 1197 piezo
attenuating 1197 piezo [message #36029] Thu, 18 April 2002 10:11 Go to next message
mhammill is currently offline  mhammill
I have a pair of 10" woofers that are only 89db eff and would like to pair them up with some motorola 1197 5x15 horns that go down to about 700hz but I'm not sure how to wire the 20ohm resistor and the exact layout or value for the cap to match the efficientcy and still use the natural lowend rolloff of the horns.I'm guessing I need to attenuate about 3-6db so I will have to try various values.
Can anyone draw me a skeet so I'm sure I get it right? I've never padded down a piezo before.
By the way after testing in my livingroom I was suprized how linear the responce of this driver and horn was from 700-18k! Can't beat it for the price.
I have some 2ft3 goodwill epi 120 boxes with good tweeters but rotten woofers that I got for $8 that will be pefect for this project.
Thank's for you help
Mike H.
Attenuating piezo tweeters [message #36030 is a reply to message #36029] Thu, 18 April 2002 11:19 Go to previous messageGo to next message
Put a capacitor in series with a piezo tweeter to attenuate it. That's all there is to it. As far as the value, I'm not familiar with the 1197, so I can't say for sure. But the KSN 1038 is attenuated a little more than 6dB using a 0.1uF capacitor.
Here's a chart:
1.0uF -1dB
0.47uF -2dB
0.33uF -3dB
0.22uF -4dB
0.1uF -7dB
Your tweeter may have different electro-mechanical parameters, and would need different values of capacitors for the same attenuation. You might want to check and find out.
Re: Attenuating piezo tweetersSORRY IT'S A KSN1188 [message #36034 is a reply to message #36030] Thu, 18 April 2002 15:37 Go to previous messageGo to next message
I got my drivers mixed up it's a KSN1188 motorola driver. Does than help? And I thought I was suppose to wire a 20 ohm resistor parallel to the driver is that right?
Mike H.
Piezo implementations [message #36036 is a reply to message #36034] Thu, 18 April 2002 19:41 Go to previous message
If you put a 20 ohm resistor across a piezoeletric tweeter, then the 20 ohm resistor becomes the dominant portion of the load impedance. The impedance of the tweeter is so high (except at the highest frequencies) that the load impedance is 20 ohms, and the impedance of the tweeter becomes almost insignificant. You could then use a standard crossover circuit that expected a 20 ohm resistive load. Check the collection of posts below for more information about implementing piezoelectric tweeters.
Previous Topic: Binding posts vs 1/4 inch jack vs XLR vs Speakon
Next Topic: 14ga solid copper wire? (for Wayne)
Current Time: Sat Nov 14 13:31:40 CST 2026
