Home » Sponsored » Pi Speakers » Wayne, what about the compensation network??
Wayne, what about the compensation network?? [message #35952] Sat, 13 April 2002 01:33 Go to next message
Erik from Holland is currently offline  Erik from Holland
Hi, wayne
Do i need a compensation network together with the Theater 4 Pi with a kappa lf and a psd2002?
You recommended the 1k6a filter to me wich should be for the 4pi with delta lf 12", but wich steepness must it have 10dB or 12dB.
Could you tell me how to build the compensation network?
You people are talking about gauge thickness of cable, could you tell me what thickness to use in metric?
Thanks Erik.
what cable to use [message #35955 is a reply to message #35952] Sat, 13 April 2002 07:11 Go to previous messageGo to next message
Zeno is currently offline  Zeno
ya i would like to know also, i am testing my Pi 4 tomorrow.
I do not have a design for the Kappa 15LF [message #35959 is a reply to message #35952] Sat, 13 April 2002 19:09 Go to previous messageGo to next message
The Theater four π Speaker uses a Delta 15A, not a Kappa 15LF. And - Yes - The appropriate crossover containing top octave compensation is required. You will need to also calculate cabinet dimensions, as we discussed in your earlier thread
Re: I do not have a design for the Kappa 15LF [message #35962 is a reply to message #35959] Sat, 13 April 2002 19:23 Go to previous messageGo to next message
I'll give you my Kappa design if you want it.
Adam
Re: I do not have a design for the Kappa 15LF [message #35963 is a reply to message #35962] Sat, 13 April 2002 19:51 Go to previous messageGo to next message
I think people would be interested. I've just been telling people to run PiAlign and build according to the dimensions given. But there have been a lot of posts about the Kappa's, so I think they are pretty popular.
Re: Taming the 1.2-1.7 midrange on Kappa 15LF motors [message #35964 is a reply to message #35963] Sat, 13 April 2002 20:58 Go to previous messageGo to next message
mhammill is currently offline  mhammill
Is this an issue? I can't decide between the delta15 and the kappa15lfa.(smooth midrange larger box/ or /better low end extention and smaller box) If the kappa15lfa could sound smooth in the mids it will be my choice but not at the expence of a realistic mid/vocal range.
Any thoughts
Thanks
Mike H
Re: Taming the 1.2-1.7 midrange on Kappa 15LF motors [message #35965 is a reply to message #35964] Sat, 13 April 2002 21:31 Go to previous message
That's a valid concern. Sorry, I don't use the Kappa's, so I can't comment.
Previous Topic: Wayne, I just can't downsize.........
Next Topic: Horn flare survey
Current Time: Sat Nov 14 13:31:47 CST 2026
