Home » Sponsored » Pi Speakers » Eminance horn bolts
Eminance horn bolts [message #35580] Wed, 20 March 2002 02:53 Go to next message
TOttman2 is currently offline  TOttman2
I just received my Eminance PSD 2002 drivers and the 290 horns from PartsExpress for my Theater Pi 4's. They didn't come with bolts. Does someone know what size and lenght I need to get ?
Thanks in advance...
Tom
!/4" 20T.P.I. [message #35584 is a reply to message #35580] Wed, 20 March 2002 05:03 Go to previous messageGo to next message
The outside pair of holes are threaded for 1/4", 20 turns per inch.
G.
Re: !/4" 20T.P.I. [message #35586 is a reply to message #35584] Wed, 20 March 2002 05:48 Go to previous messageGo to next message
Thanks for the info.
I posted on the PartsExpress Tech site yesterday... so far no response.
Tom
Re: Eminance horn bolts [message #35610 is a reply to message #35580] Wed, 20 March 2002 20:00 Go to previous message
Super_BQ is currently offline  Super_BQ
You can take a look at the photo below what i've done to fit the bolt:
The local fastener shop had a hard time identifying the alen key bolt to fit in. On the invoice the description of the bolt is "Socket Cap Screw - 6 x 16". So i assume 6mm head x 16mm long for the inside 3 bolts. $1.35NZ each so (60 cents US each).
Previous Topic: no promises but i'm try to snag one of these tube
Next Topic: More four π photo's
Current Time: Sat Nov 14 13:32:48 CST 2026
