Home » Sponsored » Pi Speakers » OK, enough lurking ... I want to try building the 3 and/or 4 pi -- Plans?
OK, enough lurking ... I want to try building the 3 and/or 4 pi -- Plans? [message #35558] Tue, 19 March 2002 05:56 Go to next message
krikor is currently offline  krikor
I've heard plans are available but I can't seem to find them on the pi site. Anyone know where to find?
Thanks.
Re: OK, enough lurking ... I want to try building the 3 and/or 4 pi -- Plans? [message #35559 is a reply to message #35558] Tue, 19 March 2002 06:14 Go to previous messageGo to next message
Decide which model you'd like to build and let me know. I'll E-Mail you the plans immediately.
Theater 3pi ... difference with Thermionic 3pi? [message #35563 is a reply to message #35559] Tue, 19 March 2002 08:16 Go to previous messageGo to next message
To keep the size down, I think I'll try the Theater 3pi. I didn't want to drop down to the 1pi or 2pi given that these use the Motorola piezoelectric tweeter ... this is based on the assumption that the Eminence titanium tweeter is a higher quality driver.
Also, what are the sound differences between the Thermionic and Theater systems? I notice that they use the Alpha and Delta Eminence woofers respectively.
Thanks!
Re: Theater 3pi ... difference with Thermionic 3pi? [message #35566 is a reply to message #35563] Tue, 19 March 2002 11:54 Go to previous messageGo to next message
Excellent choice.
Actually, the tweeter is excellent but the overall speaker design doesn't provide as much dynamic range or as deep bass as the larger speakers do.
>> Theater systems?
They sound pretty similar, but the Thermionics can be used on tube amps while Theater Series three π speakers are not recommended with certain impedance-sensitive tube amps.
Re: Can you send Theater 3pi plans? Thanks! (nt) [message #35570 is a reply to message #35566] Tue, 19 March 2002 12:41 Go to previous messageGo to next message
You have mail [message #35571 is a reply to message #35570] Tue, 19 March 2002 12:56 Go to previous message
Previous Topic: Reflex loaded w bins
Next Topic: finishing Theater 4s... questions
Current Time: Sat Nov 14 13:32:08 CST 2026
