| cabinet maker screwed up again [message #35517] |
Sat, 16 March 2002 18:47  |
replay
Messages: 284 Registered: May 2009
Grand Master |
okay, my cabinet maker just dropped off my (lima demo's) premium stage 4 pi's. they look gorgeous finished in mahagony veneer. here's the problem, i gave him exterior dimemsions (based on 1" cabinets) but he made them in 3/4" and the port which was to be 10" in length is now 10 3/4" in length. so now my cabinet's have a little extra volume and the port is a 3/4" too long. will it matter? i plan on installing the drivers next week. wayne, i need your expert opinion. cheers, george
| Re: cabinet maker screwed up again [message #35518 is a reply to message #35517] |
Sat, 16 March 2002 20:18   |
Messages: 19105 Registered: January 2001
On the volume - It's no problem. For one thing PiAlign tends towards smaller cabinets and volume tolerance is pretty large, and for another, we could always add displacement material inside if we found it to be out of tolerance too much. On the port - Can you remove 3/4" length? Does the cabinetmaker have tools that could easily remove this much material from them? They are pretty close to the rear and side of the cabinet, so it might be difficult. But the port dimensions require much tighter tolerance. I honestly think that you're OK, and certainly this is true with the overall cabinet dimensions. You'll find that if you go one direction - towards overdamped - the bottom cutoff frequency strats to rise rapidly after a certain point. But until you reach that point, response doesn't hurt much by being a bit overdamped. And going the other direction, you'll reach a point where peaking starts to rise fast. Before that, you aren't going to have a bad response curve and can barely tell the difference and then suddenly, there's nothing you can do to remove the peak. So those two points - one towards the overdamped and the other towards underdamped - are what I'm talking about when I say "in tolerance." The window between these two events is pretty wide for PiAlign'ed cabinets. It's a very conservative alignment. So that 1/4" is almost nothing, so as long as its braced sufficiently, you're in business. And I'll check the response curve for the port and double-check my assumption on the cabinet volume too. I'll let you know by tomorrow afternoon.
| Re: cabinet maker screwed up again [message #35525 is a reply to message #35517] |
Sun, 17 March 2002 05:45   |
bmar
Messages: 346 Registered: May 2009
Grand Master |
George I can transport the drivers, if you would like to test the JBL 2226 in your new cabinets at Lima, Midwest Audiofest. I dont know if the hole and bolt up is a match or not. Bill
| Re: cabinet maker screwed up again [message #35531 is a reply to message #35525] |
Sun, 17 March 2002 08:37   |
replay
Grand Master |
hi bill, i'm loading the cabinets with kilomax 15" and bringing along the psd2002 with the h290. i'd love to try the jbl's but am concerned if the box is right for this driver. the woofer cutout is 14" so it should fit. cheers, george
