Home » Sponsored » Pi Speakers » Wadding and/or Dampening a speaker cabinet
Wadding and/or Dampening a speaker cabinet [message #35173] Sat, 23 February 2002 06:44 Go to next message
Rudi is currently offline  Rudi
I made a pair of 3 way pa loudspeakers out of chipboard [3/4 inch thick] [dimensions of the twin ported cabinet.100cm hight by 50 cm depth by 40 cm wide]
I've wadded only the back panel,and put bracing across the middle to help stop unwanted vibration. BUt When I remove the polywool wadding
It makes it much more effient and is much louder. So Is there any point wadding ported or vented cabinets. I know Infinite Baffle [sealed] cabinets need wadding to operate properly.
Cheers -Rudi
Re: Wadding and/or Dampening a speaker cabinet [message #35174 is a reply to message #35173] Sat, 23 February 2002 08:51 Go to previous message
Polyfill in ported enclosures can do some good, but putting too much in will do more harm.
If you have your woofer producing higher frequencies, the damping material will help obsorbe those frequencies inside the box, preventing standing waves and smearing from those frequencies eminating from the port. It will also serve to enlarge the cabinet somewhat as the woofer perceives it.
If you add to much stuffing however, it destroys the function of the ported box. It'll run more like a sealed box. That might be your problem.
P.S. polyfill in a sealed box is by no means necessary, but usually won't hurt.
Adam
Previous Topic: JBL SCOOPS>>>
Next Topic: pair of kr62bsi monoblocks for lima!
Current Time: Sat Nov 14 13:17:18 CST 2026
