Home » Sponsored » Pi Speakers » How do you guys do your measurements??
How do you guys do your measurements?? [message #35146] Sun, 17 February 2002 10:57 Go to next message
Robert Hamel is currently offline  Robert Hamel
Hello, I am in the middle of getting my project together and was wondering what types of measurements and how you do them?? I have an SPL meter and a crude 10 octate RTA set-up. So I can do them nearfield but how do you guys do the system measurements say 6-8 feet out so its all blended while minimizing the rooms contributions?? I have one cabinet built and I am attempting the crossovers now. The obvious thing would be to measure outside but that is just not practical. I am in NY and its too damn cold and the speakers are way to heavy to get up and down stairs. Any ideas would be appreciated.
Thanks Rob
Measuring loudspeaker performance [message #35152 is a reply to message #35146] Sun, 17 February 2002 18:45 Go to previous messageGo to next message
You might check out the shareware measurement system "Speaker Workshop" at Audua.com. It is a gated MLS system, so you can gate out early reflections when doing indoor measurements. This is called pseudo-anechoic, because while the room still causes reflections, the measurement system gets its samples prior to the first arrival. Therefore, no reflections are present in the gathered dataset. The thing is, it can only work down to the frequency range where boundaries are more than a wavelength distant. This prevents you from accurately measuring the bass. You'll have to go outside for that.
On the other hand, you may want to measure the sound distribution in your room. This will not require gating. You can do that with your RTA or with gating turned off in Speaker Workshop. You'll need to make several measurements in the room, forming a grid of listening positions. Put the microphone in the first grid position and take a measurement, then move on the the next spot and so on until all grid points have been done. Then you will be able to see response at each of these points, and you will then know the energy distribution is in your room at all frequencies.
measure where the rubber meets the road [message #35153 is a reply to message #35152] Mon, 18 February 2002 03:59 Go to previous messageGo to next message
I.E. in the listening room itself. Those peaks and dips, don't sweat them too much. My main spl use is to insure that the "overall" LF and HF levels match well. Absolute accuracy is not essential...just the ability to ascertain that the HF is not way hotter or cooler than the LF. And there is a wide window of "sounds good" before you tweak yourself to the top of the bell curve with "perfect" level matching for your specific listening environment and tastes. Sam
Thanks I will check it out! nt [message #35160 is a reply to message #35152] Mon, 18 February 2002 19:00 Go to previous messageGo to next message
nt
Re: measure where the rubber meets the road [message #35161 is a reply to message #35153] Mon, 18 February 2002 19:15 Go to previous message
Hello Sam
That's about what I have been doing. Just looking for a better way. You are absolutely correct about that window being big. I had the driver in with no fiber glass and the back panel just laid in and the first cut sounded real good. Didn't measure as good as it sounded but I was sure happy. I am trying to determine if I have a room issue or a sensitivity issue. My cabinet is tunned for 50 Hz and crosses over with a L/R at 250 hz so at 250HZ I am down 6 db and the peak is right smack in the middle of the too!!! I already tried the woofer full range and the peak is still there so I am leaning towards the room. I have not moved it yet as that is the next step. This sure does keep you thinking. Thanks for the encoragement.
Previous Topic: another horn hater www.audioperfectionist.com
Next Topic: 800hz ksn1188 fourPi alpha crossover an horn
Current Time: Sat Nov 14 13:17:54 CST 2026
