Home » Sponsored » Pi Speakers » Four Pi Bass Reflex Driver mix of JBL HF motor & Delta 15 Pro
Four Pi Bass Reflex Driver mix of JBL HF motor & Delta 15 Pro [message #34831] Mon, 21 January 2002 14:09 Go to next message
anna is currently offline  anna
Hi Wayne. I E-Mailed you last week. Thank you for your response. After looking at your lineup, I think I am interested in the Theatre Four Pi. Can the JBL 2426 be used with the Eminence 15" Delta Pro? Would the balance be OK?
Second Subject. I have a JBL D130 & 075 Ring Radiator. They sit in a falling apart very old HeathKit enclosure. My Paramour easily drives them very nicely to a good ( for me ) level. Does your Professional Series relate at all efficiency ( or soundwise) to my old mono setup? I have loved my D130 over the years. I have had it since 1957. Anyway, I would consider the Pro Series if my Paramours could handle it. I know my old McIntosh 250 amp will. I would appreciate your comments.
Matt Reddington in Dayton
I would appreciate the plans for the Four Pi Theatre speaker.
Re: Four Pi Bass Reflex Driver mix of JBL HF motor & Delta 15 Pro [message #34834 is a reply to message #34831] Tue, 22 January 2002 01:42 Go to previous messageGo to next message
The JBL 2426 compression driver can be used in place of the Eminence PSD2002 in the Theater Series four π speaker. However, I think your money is better spent upgrading the woofer than the tweeter. I'd much rather have a speaker with a JBL 2226 and an Eminence PSD2002 than one with an Eminence Delta 15A and a JBL 2426.
I've sent plans for the Theater Series four π speaker which uses an Eminence PSD2002 or JBL 2426 compression tweeter. Let me know if you'd like plans for the Professional Series four π, which uses a JBL 2226 and PSD2002 or 2426.
Re: Four Pi Bass Reflex Driver mix of JBL HF motor & Delta 15 Pro [message #34837 is a reply to message #34834] Tue, 22 January 2002 07:01 Go to previous message
Wayne: Thanks for the information and quick response. Would you send me the plans for both the Four Pi Theatre and Four Pi Pro Series with JBl motors.
mdr@tdc-group.com or mattr@core.com
Regards,
Previous Topic: Beginner seeks help with “the usual question”
Next Topic: Wayne, bracing restricting port flow?
Current Time: Sat Nov 14 13:17:50 CST 2026
