Home » Sponsored » Pi Speakers » Peavey CH-3
Peavey CH-3 [message #34788] Thu, 17 January 2002 09:17 Go to next message
Hey Wayne,
I ordered two Peavey CH-3's yesterday for my first two speakers.
I'm just curious what the dimensions of these suckers are.
Thanks.
Adam
Re: Peavey CH-3 dimensions [message #34796 is a reply to message #34788] Thu, 17 January 2002 16:18 Go to previous messageGo to next message
The baffle cutout is 12.5" x 4".
Re: Peavey CH-3 dimensions [message #34807 is a reply to message #34796] Fri, 18 January 2002 10:09 Go to previous messageGo to next message
SirAdam is currently offline  SirAdam
Thanks man!
What's the radiation pattern? 120x40?
Adam
Re: Peavey CH-3 dimensions [message #34808 is a reply to message #34807] Fri, 18 January 2002 10:24 Go to previous messageGo to next message
It's a 90 x 40 horn.
Oh got another pic for you Wayne [message #34809 is a reply to message #34808] Fri, 18 January 2002 10:32 Go to previous messageGo to next message
Dah I was guessing 90x40 but changed my mind at the last second lol.
Here's the pair constructed in rough. I'm gonna get to work on the bracing and finishing touches this weekend.
You were right about the enclosure volume, btw. I overcompensated by about 0.7 cuft after woofer, brace, horn and port displcement. Actually, it'll be more now because i guesstimated the horn displacement with a 15"x8" mouth. So some adjustments will definitely be made and there will definitely be a marked improvement with that and the foam!!!
Adam
Cool! [message #34816 is a reply to message #34809] Fri, 18 January 2002 13:48 Go to previous messageGo to next message
Those speakers really look great! They're gonna sound great too, I'll bet.
Re: Cool! [message #34821 is a reply to message #34816] Fri, 18 January 2002 15:04 Go to previous message
lol... Yeah HOPEFULLY.
Actually, this second one sounds considerably better. In the first design, I didn't fasten the two reflectors of the horn to eachother because there was a slight misalignment. I was able to correct the problem in this second enclosure, so the two panels are securely fastened to eachother. It seems to have helped things. They are sounding a little better after a bit more listening.
And I actually *didn't* overcompensate with the additional enclosure, when I double checked it I made a major calculation error. After all displacement, a little polyfill and the internal volume should be right on target.
I'll keep ya updated!
Adam
Previous Topic: The review only Garland's been waiting for!
Next Topic: Need some Pi speakers at our gathering!
Current Time: Sat Nov 14 13:17:37 CST 2026
