Home » Sponsored » Pi Speakers » Rear ports for PA speakers?
Rear ports for PA speakers? [message #34758] Tue, 15 January 2002 15:42 Go to next message
RyanH is currently offline  RyanH
Is there any disadvantage to putting rear ports on stand mounted 2 way PA speakers? I plan on building some with 15" Eminence Kappa 15LFA woofers, and since these need to be easily lifted, I don't want the sides (i.e. handles on the sides) too far apart. I want to make the baffle as narrow as possible (to an extent) and put the ports on the back. Would this do any harm? they will most likely be out in the room a little, I can't imagine them being jammed against a wall or something. Another option is to just put them under the woofer (not offset to the side), this would work too, but I just want to know all of my options. Thanks!
--Ryan
Ports in the back why not? [message #34759 is a reply to message #34758] Tue, 15 January 2002 18:16 Go to previous messageGo to next message
Robert Hamel is currently offline  Robert Hamel
For what its worth I have 6 pairs of reflex speakers. 3 are front 2 are rear and one points at the floor. Doesn't seem to matter as long as they have room so they are not blocked. Both my centers are rear facing too.
Helmholtz resonators aren't "picky" about placement [message #34765 is a reply to message #34759] Tue, 15 January 2002 22:02 Go to previous messageGo to next message
Port placement isn't critical except in some cases where standing waves come into play. If the cabinet is tall and thin, it will develop pipe resonance and if the port and/or driver are positioned in a node, then it can cause a response peak to form. But other than that, port placement doesn't matter.
Re: Helmholtz resonators aren't "picky" about placement [message #34770 is a reply to message #34765] Wed, 16 January 2002 06:37 Go to previous message
Point taken about the standing waves. I will use some acoustic damping insulation just to be safe. Thanks!
--Ryan
Previous Topic: initial thoughts on my ten pi's...
Next Topic: 2226H vs Delta 15
Current Time: Sat Nov 14 13:17:06 CST 2026
