Home » Sponsored » Pi Speakers » Is this horn flare suitable for PSD2002?
Is this horn flare suitable for PSD2002? [message #34560] Fri, 28 December 2001 00:56 Go to next message
hjeon is currently offline  hjeon
Hi Wayne...
I bought a horn flare made by Sammi here in South Korea.
It resembles CH-3 but a little bigger.
Mouth size is 15 x 5 inches and depth is 7 inches.
so the mouth area is 75 square inches
So the horn cut off frequency is a little lower
than either CH-3 or H290 since the mouth area is bigger.
It is a bi-radial with diffraction slot at the end.
Do you think this is suitable for the PSD2002 on theater
4 pi?.
Or should I buy another horn flare?.
What effect can we expect by using bigger(lower cut off)than normal
horn flares?
Sammi make sh-350 which is similar to h290 by look and spec.
They also make sh-360 which is similar to ch-3.
If I have to buy another horn which one do you think is better?
Thanks in advance
Hunmoo
Re: Is this horn flare suitable for PSD2002? [message #34561 is a reply to message #34560] Fri, 28 December 2001 01:32 Go to previous messageGo to next message
Is it basically a 2370 copy? If it has a similar radiation pattern and response curve, it should work just fine. If you use it, please let us know how it sounds.
Re: Is this horn flare suitable for PSD2002? [message #34562 is a reply to message #34560] Fri, 28 December 2001 03:08 Go to previous messageGo to next message
Super_BQ is currently offline  Super_BQ
I've looked at the Sammi line of horn flares then found that they are a little different than the CH-3, 2370, or H-290 flares.
The Sammi SH350 is a bolt on exponential horn similar to what is required for the Theater 4 Pi's however, it's dispersion is quite different. It offers a 120°H x 90°V with a cut-off freq. of 600 Hz. I believe the 2370 and similar flares use a 90° X 40° dispersion.
Wayne, what effect would using the SH350 wide dispersion have over the typical 2370 size horn flare for the Theater 4 Pi?
Re: Is this horn flare suitable for PSD2002? [message #34563 is a reply to message #34562] Fri, 28 December 2001 10:20 Go to previous message
If I were planning to use a tweeter horn with a different pattern, I'd crossover at a different frequency to maintain DI matching. If the tweeter horn pattern is more narrow, crossover higher; If wider, crossover lower. The idea is to crossover in the frequency range where the direct radiating midwoofer pattern has narrowed to the same angle as the tweeter pattern in the horizontal. That way the sound is uniform throughout the room, within the vertical arc of the horn's pattern. Tweeter horns with asymmetrical patterns usually narrow more in the vertical than the horiozontal, which is a good thing in my opinion so it doesn't waste energy on the ceiling and the floor. You want the midwoofer pattern to match the tweeter's horizontal, because that makes off-axis response as smooth as off-axis response, which also creates a uniform reverberent field.
Previous Topic: All the T-S parameters for every JBL, OH BOY!
Next Topic: Wayne, double loading
Current Time: Sat Nov 14 13:17:00 CST 2026
