Home » Sponsored » Pi Speakers » Eminence Delta 15 same as Delta 15A?
Eminence Delta 15 same as Delta 15A? [message #34392] Wed, 12 December 2001 09:17 Go to next message
Just ordered Delta 15A's for my Theater 4 Pi's. Are these the same drivers as the specified Delta 15's? These are from Parts Express.
Thanks!
Garland
Re: Eminence Delta 15 same as Delta 15A? [message #34393 is a reply to message #34392] Wed, 12 December 2001 10:36 Go to previous messageGo to next message
Colin Fritzke is currently offline  Colin Fritzke
Yup, you got the right one. The Delta 15 comes in two flavors: Delta 15A (8 ohm) and Delta 15B (16 ohm).
Colin
Re: Eminence Delta 15 same as Delta 15A? [message #34394 is a reply to message #34393] Wed, 12 December 2001 14:00 Go to previous messageGo to next message
Don't you mean the 15LF?....thought that was the good one.
Kelly
Re: Eminence Delta 15 same as Delta 15A? [message #34395 is a reply to message #34394] Wed, 12 December 2001 14:14 Go to previous messageGo to next message
No - The only "LF" woofer used in the standard lines of π Speakers is the Delta 12LF, which is used in the Theater Series three π cabinet. Of course, you can run PiAlignments on any woofers and build cabinets for them, but the only Eminence "LF" parts I've used are the Delta 12LF's.
Re: Can of Worms, or, what the heck did I do? [message #34396 is a reply to message #34395] Wed, 12 December 2001 15:44 Go to previous messageGo to next message
Just got the latest P.E. catalogue which has Eminience Delta 15, Delta 15LF and Delta 15 Pro! Various T-S parameters:
In order:
Fs 40 41 42
vas 10.4 6.57 8.6
Qms 6.56 6.65 4.73
Qes .54 .64 .44
Qts ..49 .58 .40
Xmax 2.7mm 4.8mm 3.2mm
I used the Delta Pro in my Theatre 4's. Should I trash them? (just kidding)
Delta and Delta LF have Steel Basket, Pro is Aluminum (nt) [message #34397 is a reply to message #34396] Wed, 12 December 2001 15:59 Go to previous messageGo to next message
nt
Woofer for Theater four π loudspeakers [message #34399 is a reply to message #34397] Wed, 12 December 2001 17:41 Go to previous message
The Theater Series four π loudspeaker is designed to use the Delta 15. The Delta 15 Pro is a completely different animal but it works pretty well in the Theater four π speaker.
Previous Topic: Duplicate post from high eff.; idea for get-together
Next Topic: 7 Pi Boxplot
Current Time: Sat Nov 14 13:06:08 CST 2026
