Home » Sponsored » Pi Speakers » Mystery Drivers & Plans for the Pi 6 Theater
Mystery Drivers & Plans for the Pi 6 Theater [message #34299] Sat, 01 December 2001 18:51 Go to next message
Vello is currently offline  Vello
Wayne-
Thanks very much for the Pi 7 plans. I came across (and purchased) a a set of drivers from a late 60s Curtis Mathis stereo console unit. The woofers are a stamped basket 12" with paper cone and cloth surround, no markings other than "29B49-1" which I presume is the model number. The tweeters are a 2x6 metal horn tweeter, no markings other than "V/60". The crossover consists only of a single capacitor (4.7 uf 25VDC), no coil or anything else. The drivers are in pristine condition and I would really like to incorporate them into a Pi 6 (Theater) design. Can you offer any suggestions on determining the specs on these speakers ? Also- please email the plans for the Pi 6.
Thanks !
-Vello
Measurement equipment and software [message #34301 is a reply to message #34299] Sat, 01 December 2001 19:59 Go to previous message
I suggest using the Woofer Tester from Parts Express or Speaker Workshop from Audia. You can also measure them yourself using the following technique and formulas:
You'll need a signal generator and meter or scope. Put a test resistor in series, something between 10 and 1000 ohms.
Find Re. It is the DC resistance of the voice coil.
Find Fs. It is the frequency where impedance is highest.
To find mechanical and electrical Q values, the following formulas are used:
Qms = Fs * (Zmax/Re)0.5 / (Fh - Fl)
Qes = Qms / (Zmax/(Re - 1))
Qts = Qms * Qes / (Qms + Qes)
where
Fs is the resonant frequency of the speaker in free air (Hz)
Zmax is the impedance of the speaker at resonance in free air (ohms)
Re is the DC resistance of the voice coil (ohms)
Fh is the frequency above Fs where speaker impedance is (Zmax*Re)0.5
Fl is the frequency below Fs where speaker impedance is (Zmax*Re)0.5
Note: Fl and Fh can also be found at the points where voltage across the test resistor is equal to Vq in the follwing formula:
Vq = (Vmax*Vmin)0.5
where
Vmin is the voltage across the resistor at the speaker's resonant frequency
Vmax is the voltage across the resistor at a frequency far from resonance
To find Vas using the sealed box method, the following formula is used:
Vas = Vb((Fb / Fs)2 - 1)
where
Vb is volume of the sealed cabinet (ft3, m3 or liters)
Fb is the resonant frequency of the speaker in the box (Hz)
Fs is the free-air resonance of the speaker (Hz)
Previous Topic: Hats-Off to replay (George)...
Next Topic: Port detail for pro 7 pi's
Current Time: Sat Nov 14 13:05:18 CST 2026
