Home » Sponsored » Pi Speakers » Pi Speaker Forum
Pi Speaker Forum [message #34175] Fri, 16 November 2001 08:08 Go to next message
hi wayne and fellow inmates. as time goes by the speakers are sounding better but i still think they lack bass and high end treble. any suggestions?
cheers,
george
Re: jbl 4655 second take [message #34180 is a reply to message #34175] Fri, 16 November 2001 13:20 Go to previous messageGo to next message
Michaelz is currently offline  Michaelz
Hi, Replay:
According to the spec sheet, response falls off at 100Hz on the low end and 10kHz on top.
Regards,
Michael
Re: jbl 4655 second take [message #34181 is a reply to message #34180] Fri, 16 November 2001 14:04 Go to previous messageGo to next message
not a very impressive response chart, no top, no bottom and a big dip at crossover. should i modify these, part them out or ebay them?
cheers,
george
Re: jbl 4655 second take [message #34182 is a reply to message #34181] Fri, 16 November 2001 15:26 Go to previous messageGo to next message
You can EQ the top end to get a bit more extension, but not much. On the bottom end, I think you'll need a sub. Speakers like these are designed to be used with a sub, so they don't use alignments that offer deep bass extension. As for the dip at 1.5kHz, looks like a crossover problem to me. I'd say they would benefit from a little work there.
Re: jbl 4655 second take [message #34183 is a reply to message #34182] Fri, 16 November 2001 16:37 Go to previous messageGo to next message
hi wayne, i'm leaning towards selling them at this point. on the underside the quality words "made in mexico" are printed.
cheers,
george
Re: jbl 4655 second take [message #34239 is a reply to message #34182] Wed, 21 November 2001 10:30 Go to previous message
spkrman57
I plan to swap my 2205a for the 2032h since the 4655's are approx 2.5 cubic foot enclosures and would be close to the 2.1 cubic foot that pi align calls for on the 2205a. just my 2 cents.
Ron aka spkrman57
Previous Topic: DECISION TIME AGAIN - Theatre Three or Modified Theatre Four?
Next Topic: Mr.Parham could you please send me the theatre pi4 plans
Current Time: Sat Nov 14 13:04:23 CST 2026
