Home » Sponsored » Pi Speakers » jbl 4655 at tent sale
jbl 4655 at tent sale [message #34125] Thu, 01 November 2001 19:23 Go to next message
i'm in trouble now! just ordered 4 pairs of these speakers from the tent sale.http://www.jblpro.com/pages/install/4655bk.htm. i figured the drivers are worth triple the cost of the complete speakers. c'mon $222.00 a pair delivered. wayne, any info on an improved cabinet for these babies? or are these good enough left alone. can i build some killer's with these components?
thanks,
george
Re: jbl 4655 at tent sale [message #34126 is a reply to message #34125] Fri, 02 November 2001 06:56 Go to previous messageGo to next message
pickle is currently offline  pickle
I'd have suggested springing for two CS3115's, for another couple hundred bucks...........the 3115's have the top notch components, and could be cannibalized for a Pi cabinet.............
Re: jbl 4655 at tent sale [message #34128 is a reply to message #34126] Fri, 02 November 2001 19:12 Go to previous messageGo to next message
Hey Wayne,
I turned a friend on to the tent sale, and he called and
they told him the CS3115's are all gone. So... any opinion
on the components in the 4655's? They are rather inexpensive.
Thx, Chris
Re: jbl 4655 at tent sale [message #34129 is a reply to message #34128] Fri, 02 November 2001 21:34 Go to previous messageGo to next message
The tweeter is a 2416, which is basically the same thing as a 2426. The woofer is a 2032, which is a low-cost alternative to the 2226.
4655 uses 2032H lf driver [message #34136 is a reply to message #34125] Thu, 08 November 2001 12:50 Go to previous messageGo to next message
2032H specs from jbl
Fs 57 Hz
Qts 0.54
Qms 5.5
Qes 0.6
Vas 133.1 liters
eff 4
Pe 300 watts
Xmax 6.35 mm
Re 4.2 ohms
Le 0.6 mH
Sd 0.088 meters
Bl 12.8
Mms 65
Flux 1
personally, I have my doubts about "how low" these will play...what do you think, Wayne? BTW, the 2404H-1's look great, still 20 left. Sam
Re: 4655 uses 2032H lf driver [message #34137 is a reply to message #34136] Thu, 08 November 2001 20:00 Go to previous messageGo to next message
I'd say they probably have f3 around 60Hz - 70Hz. PiAlign recommend that this driver be installed in a 2.5 cubic foot cabinet tuned for 40Hz, which provides flat response down to system cutoff of f3 at 70Hz and f10 at 50Hz.
Re: jbl 4655 at tent sale [message #34138 is a reply to message #34125] Thu, 08 November 2001 22:07 Go to previous messageGo to next message
Those are JBL's budget models. For the tent sale price, they're a bargain.
Re: 4655 uses 2032H lf driver [message #34146 is a reply to message #34137] Fri, 09 November 2001 11:58 Go to previous messageGo to next message
I picked up a few of these to use as rear surrounds for home theatre setup. I thought they would be pretty good for this purpose.
any input.
thanks,
Bill
Re: 4655 uses 2032H lf driver [message #34149 is a reply to message #34146] Fri, 09 November 2001 19:59 Go to previous messageGo to next message
Perfect. I'll bet that's their intended application, probably what JBL designed them for.
Re: 4655 uses 2032H lf driver [message #34150 is a reply to message #34149] Fri, 09 November 2001 22:14 Go to previous message
excellent! I also have a few 3115's coming my way. I will be asking your assistance for a Pi enclosure and crossover for these components.
I am going to have to open them up when they arrive to get the actual motor specs. I have info from JBL that states the 2226 is 4 ohm and the hf driver is a 2425 and not a 2426. might be better to start a new thread when I have all the correct info and more to ad about the room and what I would like them to do.
thanks as always,
Bill
Previous Topic: Wacky results for Rat Shack 90-1197 in PiAlign?
Next Topic: voigt pipes vs corner horns
Current Time: Sat Nov 14 13:05:30 CST 2026
